L2201DT transmission/hydraulic filter
TractorTim
Kubota L2201DT
Oct 10, 2024
England
Hi all, does the L2201DT have a transmission/hydraulic fluid filter..? The L245DT is generally the same tractor and does have a filter but I cannot see in any manual that the L2201DT has one. Any comments appreciated…
TractorTim
Kubota L2201DT
Oct 10, 2024
England
My L2202DT has one same side as the engine oil filter.
Is it a filter same type as engine oil filter…ie external screw on canister type..?
I don’t know the difference between L2201DT and L2202DT.. I will research.
many thanks for your response..appreciated.
1,985
I don’t know what your tractor has but Kubota has a few types of filters for hydraulic systems:
Screw on similar to an oil filter
Canister style where the filter is inside a steel container
Screen type that is inside the transmission (on my L185)
Flintknapper
L2350DT
May 3, 2022
1,929
2,434
Deep East Texas
IF you can find no external filter...then likely it has a filter 'screen' inside the trans case, which is accessed via a cover on the outside.
As an example (my L2350DT):
Thunder Fish
ZL2202DT-M
157
42
100 Mile House BC,Canada
Yes it is but that really has no meaning,the tractor came with very small filters being used.
1,985
View attachment 139738 Bottom is the engine top is the hydraulic,hope this helps
@Thunder Fish - are you talking about the two white filters in the picture? Isn’t one the fuel filter (left most white filter that is vertical)
In this picture of a L295 I see three filters and crudely marked them:
F is the fuel filter
O is the engine oil filter
H is the hydraulic fluid filter (canister filter type) as I understand it.
Thunder Fish
ZL2202DT-M
157
42
There we go,thank-you,I stand corrected
