M5-111 small rear window replacement suggestion?
JmacM5
M5-111
Jul 15, 2024
Floresville, Tx
I just purchased a new M5-111 hdc24 and 10 minutes of shredding produced a shattered lower rear window. It looks like I simply need to glue new one in place?..if so what product is suggested?..thks
Bmyers
May 27, 2019
3,452
4,304
Southern Illinois
Do you have KTAC insurance on it?
JmacM5
M5-111
Jul 15, 2024
Floresville, Tx
No..bought farm bureau insurance but may switch if this keeps up..haha
I purchased window $170 and looks simple enough to install (don’t have time to take into Kubota for replacement) but was hoping someone has hands on experience with glue type or info. on install…
Bmyers
May 27, 2019
3,452
4,304
Southern Illinois
I'm sure someone will come along with that knowledge. My experience would of been to call the insurance and the dealer, so I'm not much help. Yet there are several knowledgeable ones on here that can give you the correct guidance.
4,886
Maybe there’s something different about Kubota tractors and if so, I’m open to correction. However, auto glass replacement and equipment cab glass replacement, in my experience, requires a urethane adhesive sealant specifically made for the task. (Just an example; not a specific recommendation.)
Remove old glass, clean off old sealant thoroughly, follow any other directions on the urethane adhesive, “clamp” new glass in place with strips of tape oriented perpendicular to the joint. Remove tape after about 24 hours.
JmacM5
M5-111
Jul 15, 2024
Floresville, Tx
Thks…every bit of info. helps👍
3,186
1,604
The glass is mounted using urethane.
Before you install the glass, put a line with a marker down the center line. Put a mark on the cabin at the center line so that when you are laying the glass onto the adhesive, you can position the glass.
It is very annoying to be standing on the drawbar, the upper part of your body hanging into the cabin through the rear window trying to see that the new glass is covering the opening. If you miss, you get to clean the urethane off the glass and cabin so you can try again.
JmacM5
M5-111
Jul 15, 2024
Floresville, Tx
Thks so much for the info. White Tiger👍
