Any one with a bx 2230. I need to know the front tire size and make of a lug tire. Mine has turf tires and I want to change to lug, but I can not find the same size.. 18 8.50 8.
I think your tractor should have 18-8.50-10. the 8 inch wheel is for the bx1830. The rears should be 24-12-12.Any one with a bx 2230. I need to know the front tire size and make of a lug tire. Mine has turf tires and I want to change to lug, but I can not find the same size.. 18 8.50 8.
You are right! I misread your model # as a BX2350, sorry!The rears are 26 12 12, but the fronts are 18 8-50 8. That is what was on it when I bought it. It's about an '04 model.
murphy,, those are 18 9-50 8... I need 18 8-50 8.. Thanks for looking for me.
murphy,, I had the 9-50 on this winter. I could really tell the difference in the load when 4wd was engaged. For some stupid reason, I did not know I had 9-50 instead of 8-50 untill I took them off this week and was compareing diameter. The 9-50 is a taller tire. I was trying to figure out rollout distance and my mechanic said, " You've got 2 different size tires between the turf and ag." A 9 is 3/4th of an 8 when you can't see good.!!! I've been all over the web and can only find 1 place that has them. It's an auction co, and they have 4 tires and wheels but the wheels are not Kubota. The tires are Maxxis, but I can not find that size anywhere on the web, even on there site.
rc,,, rollout circumference????? The rear ag tire I have is actually smaller allthough it has the same size # on the sidewall as the turf. It's 1 1/4 inches less in diameter that the turf tire, oe. The ag front is 3/4 inch larger in diameter than the turf tire, oe. That creates too much lead pull.
