Lever hooks sheared off
Dcguinn
BX2380, LA344, 54” MMM, 26BX Bagger, Tiller RTA1242, Forks PFL1242, Grapple mine
Sep 1, 2021
24
9
Ellijay GA
Finished mowing, it’s getting late, I want to reattach the BX loader. Drive up, attach hydraulics, drop hooks and maneuver to set the loader in the frame. Ping ping, both little spring mounts shear off. I’m sure I’ve stressed them before but weird. Back to Messicks for updates. Obviously overdid something.
Nicksacco
Sep 15, 2021
710
422
Bahama, NC
Oh no! Not a great way to end the day.
Maybe a picture or two of the damage?
Keep us posted
Dcguinn
Sep 1, 2021
24
9
Ellijay GA
Well, after I settled down and thought a little, I tested the steel to weld Which worked. Then Pulled the parts, separated the loader, welded both sides each, tested, installed and now; good to go. I must have dropped the clips too early and did a move to stress them. Anyway, thanks for the interest.
JimDeL
Aug 31, 2022
356
401
Austintown, Ohio
FWIW, When I remove my loader I immediately move those levers to the down position.
When reattaching the loader the clamps just spring into the locked position without my touching the levers.
That's the way the dealer showed me when I bought the tractor.
Bearcatrp
Mar 28, 2023
858
494
Minnesota
Always read issues with the loader that has been removed at some point. I haven’t removed mine since buying it for fear of some issue cropping up.
Dcguinn
Sep 1, 2021
24
9
Ellijay GA
Mine were down when I heard ping ping. Probably halfway seated when I did something jerky. I’ll be more observant, thanks.
Dcguinn
Sep 1, 2021
24
9
Ellijay GA
This was my first tractor, 195h now. I get paranoid about things, but also refuse to be intimidated. I needed to mow a wet bank yesterday and didn’t need the extra weight. If you commonly remove and attach the loader and other implements it’s easier. It took a bit to learn how to clear the frame arms, but pretty straightforward now.
Bearcatrp
Mar 28, 2023
858
494
Minnesota
I just remove the bucket or forks I have on it but leave the loader on. At some point I’ll get the spacers for the rear wheels to help with slopes.
Dcguinn
Sep 1, 2021
24
9
Ellijay GA
I got spacers with a 54” deck. I think they are just under
I got spacers with the 54” deck. I think they are just under 2.5” but it’s been a while. They are very close to rubbing the tread.
JimDeL
Aug 31, 2022
356
401
Austintown, Ohio
With a 54" deck 1½" is as large as you can go.
Dcguinn
Sep 1, 2021
24
9
Ellijay GA
Ah, couldn’t recall. I do remember it was less than .5, so 1.4 then. They do help, but I still don’t Ho over 20° side to side.
