Replacing Thermostat and Gasket on L3200HST
Sammy3700
Feb 20, 2012
457
60
Red Springs, NC
I only use the gasket on any engine most slide on the mounting bolts torque the bolts to specs all should be good
Atlanta Panther
Kubota L3200HST with Loaded R4 Tires, LA524 Loader and Quick Connect 66" bucket
Jun 15, 2013
77
Madison, Ga
To add to the question...went to the workshop manual and it says,
" Thermostat Assembly 1. Remove the thermostat cover mounting screws, and remove the thermostat cover (1). 2. Remove the thermostat assembly (3).
(When reassembling)
• Apply a liquid gasket (Three Bond 1215 or equivalent) only at the thermostat cover side of the thermostat cover gasket (2). What does this mean?
• Apply a liquid gasket (Three Bond 1215 or equivalent) to the water flange 1 (4) and flange 2 (5) "
So looking up on Amazon I find:
Threebond Of America Rtv Silicone Gray Eng Sealer Tb1215
and it says in the description:
  • Liquid gasket
  • Use in fits Case to fits Case Where NO GASKET is used
The WSM and the description seem to be in conflict.
What should I do? Thoughts?
BTW, I also found that
LocTite/Permatex #599 Ultra-Grey and 3M T-3 Silicone (black) #08670 are both equivalents to Threebond 1215.
RedTailHawk
46
Capon Bridge, WV
(When reassembling)
  • Liquid gasket
Curious if you got any resolution on this…
