Inner tube or no
Flintknapper
L2350DT
May 3, 2022
1,995
2,524
Deep East Texas
Yes, but depending on WHY the tire/wheel is leaking.....might be better to just fix it. With a tube, IF you have a puncture....you'll need to remove the tube to repair it.
Ken alaska
Bx25d
Jul 17, 2024
Alaska
Thanks,, I’m just getting used to the machine. She only had a 100 hrs on her. And was kept covered for years. Runs great. 40 years on the water, so I’m a duck out of water.
bbxlr8
Mar 29, 2021
436
301
Eastern PA
pump it up - slather on soapy water & see what you see
check & tighten valve stem core?
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
241
280
CT
Got tired of small leak between rim halfs on front of b2150 so in went a tube today.... corrosion between rim halfs and rubber seal leak....repainted inside of wheel and new tube....done.
sdbrison
B2150
Jul 22, 2024
TN
Where did you get your tube and what size was it? I have the same problem with my front tires and I think a tube is the best first step. Finding the same size tire I need for my b2150 has been a challenge. Current tire is 24x8.50-12 and I have patched it multiple times
Oleracer
Jul 18, 2024
241
280
CT
Never found exact size but with tubes close is good. (Fix / sold tires 45 years)
23x8.5/9.5/10.5-12 was the size i used.
amazon was like 33 bucks for 2. Others wanted 30 bucks for 1.
my rims look brandnew but the rubber seal between the rim halfs were covered in rust. Just like rim halfs. Older compressors dump lots of water in tire when filling tire. ( i have dryer on my compressor)Ground down inside of rims. Repainted .. cleaned up rubber seal and all good. They probably would have resealed but i figured 33 bucks was good insurance.
sdbrison
B2150
Jul 22, 2024
TN
Thanks. I'm going to do tubes for short term and see how it goes. Is there a source for 24x8.50-12 tires. My rears are in pretty good shape and don't want to go thru changing out fronts and backs. Google has plenty of results but it seems it comes up as 23 or 9.5 or.... When I find a site with that size they are out of stock.
Thanks again for your response.
Oleracer
Jul 18, 2024
241
280
CT
Hope you found the tubes…. Mine worked very good . Tires holding nicely
sdbrison
B2150
Jul 22, 2024
TN
I did find tubes and they have been holding fine so far for several weeks (knock wood). I haven't used it a lot but I think it will do the trick for now. Thanks for your help.
