Loader Control Valve
captfrank
Kubota B7200 DT, 1750 HST, RC60B Mower, Woods M40 Rotary Cutter, B1630 Loader,
Jun 8, 2020
Roanoke, VA
I have a 1640A loader on my Kubota B1750. I need an entirely new lever control. [I moved the one that was on it to my B7200 to replace a completely worn out one] I am also planning to put a third function on the 1640A (B1750) so that I can add a front grapple. Of course, Kubota prices for a new controller are out of sight.
Does anyone have a recommendation for a new controller that would incorporate a third function? Or a new controller and an add on third function?
Thanks for any input you could provide.
Frank
6,058
Thanks for any input you could flostprovide.
Frank
Nothing special needed and plenty of choices. Two quick examples:
Cheap joystick loader valve with float and a power beyond port. Pretty much plug and play on that loader:
Generic electric third function from same source. You would have to do some minor bracket fabrication to mount it on the loader tower next to the joystick
Those are not recommendations just examples and about the least expensive going.
captfrank
Jun 8, 2020
Roanoke, VA
Dan:
Thanks for the direction. It will save me tons of think/research time.
Frank
captfrank
Jun 8, 2020
Roanoke, VA
Frank
Frank
Dan:
Frank
Dan:
Frank
OK. I installed the summit hydraulic directional control with the joy stick. Loader works great, but 3 point hitch will not work unless I bypass the loader by disconnecting the input from the loader and only using the 3 point. Suggestions??
captfrank
Jun 8, 2020
Roanoke, VA
6,058
First thought.
Did you purchase and install the power beyond conversion sleeve? Sounds like its plumbed without it
Pictures also convey a lot of information.....
captfrank
Jun 8, 2020
Roanoke, VA
First thought.
Called Anthony at Summitt and that apparently is the issue. Ordered the Power Beyond adaptor sleave. Expect that will solve it, I hope.
