L35 Fitting Failure
BELLSHIREGUNS
L35
Jun 26, 2024
NASHVILLE
Has anyone had a stabilizer leg hydraulic fitting separate at the 90 deg angle? Looks as if it was pressed together rather than being one piece
Nicksacco
Sep 15, 2021
712
422
Bahama, NC
Interesting. Did it just blow off when you lowered the stabilizer?
Do you have any other pics such as the part that blew off?
BELLSHIREGUNS
L35
Jun 26, 2024
NASHVILLE
No blow off. I was in the process of removing the hose and it separated with very little resistance. FYI I am restoring this tractor after acquiring it from an estate as a free tractor if you can get it off the property. Unfortunately it set idle for 15 years, so I have my work cut out for me.
Nicksacco
Sep 15, 2021
712
422
Bahama, NC
I spent about 3 years restoring mine from the ground up. The L35 TLB is a nice machine.
I've posted a lot of stuff on here as tbe restoration progressed. Many others have too so look around.
L35
Jun 13, 2010
582
516
CT
L35 is a monster. I like it so much I named myself after it. Let’s see some pics, free is outstanding. Good luck!
5,170
My friend calls his M62 ..... "a beast"
L35
Jun 13, 2010
582
516
CT
All the Kubotas that come from the factory as TLBs really seem to be overbuilt. I’m never underwhelmed by mine, hopefully parts stay available for a long time so I can continue to enjoy it.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
64
54
Shelton, Washington
I really like my L48. Definitely overbuilt. The only weird thing is the turning brakes on the same side as the treadle pedal. No biggie though.
Doug
