FOR SALE - B7200DT with B1630 loader
3,485
Located in Hagerstown MD.
Loader is in excellent shape with 4 new cylinders and fresh hoses..
Tractor starts easily, runs and drives fine but needs TLC. Brakes are oil soaked and need to be replaced. New druns, pads, and oil seals included in sale. Four wheel drive is not wotking. The output shaft (aka reverse shaft) in transmission has sheared at the external end where it connects to u-joint on front ptopeller shaft. As a result tractor is currently 2WD only. Messicks lists a new shaft for $190. Replacement requires a complete disassembly of theo transmission.
I will sell loader for $2K. You remove and I will load on your truck or trailer.
Or purchase tractor and loader for $3K snd you can drive it onto your trailer.
