Modified/adapted snow plow.
C1skout
Bx2380
Sep 2, 2022
PA
I wanted a front mount snow blade to attach on my loader, so I modified an old Bolens 42" blade that a friend gave me. Here it is near the start, along with the old water heater tank that I used to extend the plow.
I added around 11" to each side, and built new rear ribs from flat plate. Lower structure is simple 2" angle iron.
I modified the old Bolens framework too. I widened the attachment points, put in some spreaders, and a piece of pipe to drop a 1/2" pin through to hold the angle adjustment.
Here it is all painted and assembled. I got the quick attach blank plate from Amazon. I decided to just weld the skid shoes on solid.
I got a 1/4" plate cut 60" wide for a cutting edge, and centered the bolt holes so it's reversible to use both sides.
Maybe it'll be good enough to keep us from getting any snow this year.
Reactions: 8 users
5,778
NICE !!! just had 1 kid for trick or treat AND several SNOW flakes.......sigh...
I made a gas powered SSQA dual 24" blower 4 years ago....it kept most of the white away, so never used it
trial and error
Feb 16, 2023
394
386
NY
Nice job, I want the white stuff so send it my way but I need about a month to get leaves done
Edit: if those are the original trip springs you may need to either add additional ones or replace them with stiffer ones. I made a plow some years ago for a lawn tractor out of plate steel I recylced from a building. The biggest hurdle was the trip springs and getting the plow to not just flop over when it got loaded up
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Looking good, Sir!
Cheap investment...Big reward 👍
C1skout
Bx2380
Sep 2, 2022
PA
I did think about the springs. I found some that are similar sized and made for a 60" plow, but figured I'd try it first and see how they work. Easy enough to change them later.
animals45
L3301l
Apr 22, 2021
282
Mabie CA
Nice job . How much did ya have to change the water heater arc to match the blade ? If thats a real Bolens blade , like from 60-70's them springs are pretty hardy . Bolens built their tractors & implements to last back then . I have 3 that run & another waitin for the rite rainy month . DO ya have a link for the SSQA plate ?
thanks
animals45
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Yeah, not counting paint, weld wire, my time, or junk I had laying around, I only put about $150 into it!
RePurposing, when the payoff is something that is as-good or-better and you built it, is win/WIN.
C1skout
Bx2380
Sep 2, 2022
PA
thanks
animals45
The heater tank panel was close enough that I just bounced on it with my feet to bend it some, then used C-clamps to hold it for welding.
Here's a link to the plate. It went up a couple bucks since I ordered mine at $119.
Glassman13
51
10
Amherst Ohio
I did the same thing with a J Deere 44in. blade. Mine attaches with padeyes in the pin on bucket on my 2301. The inside of the water heater was very rough , the glass lining?, that I end up using the outer metal cover , the white side out, to help snow peel off the blade. It also added weight which helps. Altered the skids and trip springs .
