BX 2660, 2350, 2360, bx24 and bx25 owners
manofaus
bx2350
Mar 23, 2012
55
Australia
I have a BX2350 and have noticed a hole in the plastics for another lever. On the right hand side of machine, I have a high low, 4wd/2wd selector, and 3pt raise and lower. It looks like it was made for another lever. Do the other models that use the same frame or updated models have a lever in this hole? I would like to add an hydraulic adjustable top link and I think I could manage to put a lever through this hole to make it look factory, unless I could get a factory valve or whatever in there. My dealer left town and its a 2 hr drive to get to the closest one.
thanks
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,130
126
Hardisty, Alberta
that is for the factory rear remote lever. the factory rear remotes are expensive.
Timdale is right, there is a remote valve available for that location, and, considering it is a dual remote valve, not all that expensive! I have one on my BX24, though it isn't really recommended for the TLB's! It requires some creative work with a torch and welder to effect enough clearance to install the valve and connecting lines on the BX24 and BX25. No problem installing it on the other BX models though! ( I use it for my hydraulic top link and a tilt cylinder I made for the TPH)
timdan94
L 2501 TLB
Oct 25, 2011
45
Liberty Pa
I have a bx 25 and would like to add the remotes. do you have pictures of your install. thanks
eserv
May 27, 2009
2,130
126
Hardisty, Alberta
I don't have any pictures :( You must cut a piece out of the frame and reinforce it and none of the lines will work they must all be custom made! Not an easy job at all!
Ed
eserv
May 27, 2009
2,130
126
Hardisty, Alberta
Ed
I wouldn't do it again!
Ancbill
Bx2360, 54" mmm, BX2750D snowblower, RB0560 rear blade, psycho border collie
Dec 17, 2011
49
Anchorage, ak
For a the bx2350/60 or bx2650/60, you want to order the rear hydraulic auxiliary kit model bx7326. I've seen photos, it's a real nice factory aux hyd kit. It runs $350 to $400.
It's on my to do list! Then I can modify my rear blade for hyd angle and add a hyd top link too.
ipz2222
L235, bx2670
May 30, 2009
1,927
31
38
chickamauga ga usa
mano, on my bx2230, it has another lever called "cruise". Push the hydro pedal to whatever speed you want, move the crusie lever on and let off the hydro pedal, the pedal stays locked untill you press the hydro pedal again. Totally useless unless you have a flat 2 acre field to mow.
manofaus
bx2350
Mar 23, 2012
55
Australia
thanks lads. The cruise on the bx2350 is on the rh side of the dash panel. (works well on my 3 acres of flat feilds!!)
