[MOD] Adding a step. BX23S
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
These are ready-made, used in conjuction with internet/server pedestals. Sizes are written. See images
Only one for now. Plot, drill & bolt.
5,464
Looks nice.
I would probably add some "Skate Board" tape, or paint the topside with truck "bed liner paint" to add some "slip protection"
The Rustolem bed liner paint at Wally world works pretty good for 20 bucks a Quart (or half gallon..... I can remember)
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Do you run a MMM ?
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Looks nice.
If I can find some, I have plans to put a piece of Aluminum or Stainless Expanded material to make it non-slip.
If I can't find any, I'll drill, tap, and Loctite a dozen or so short Stainless bolts.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
VERY COOL.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
VERY COOL.
Thanks.
I did not have the deck on, or test for interference prior to making the step. I kept the bottom of the step flush with the bottom of the rail that supports the FEL Pedestal/floor pan, so it "should" clear the mower deck when raise at the highest setting.
I'm undecided if I want to add a step to the tredle side. If I do it's purpose will go unused, because I'll block that side entirely by mounting my toolbox there. Which I just might do eventually. As a Winter project. Tomorrow 🤣🤣🤣
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,336
857
under a rock
Nice work but I really don't see the point...
unless you are very short in stature.
not exactly hard to step onto a small homeowner garden tractor....
Trimley
Jul 25, 2023
1,181
872
PNW-WA
I cut grass with my BX23s and do not step on the deck. Adding a step helps alleviate the stride distance, and I have a plan. More to come. 😉
6,308
great, now I have a use for the 1/4" checkerplate I've squirreled away for the past 25 years.
punch a couple holes , a bend,lick of paint....might be a 'winter project' I actually complete this winter !
Trimley
Jul 25, 2023
1,181
872
PNW-WA
The Aluminum, I had a couple pieces of 1/4" tread already bent in my scraps. The bends had too many stress cracks to trust not ripping apart. Had I used them, they would have needed supporting. At that point I may as well used wood and Simpson Hangers.
check 6
BX 2680 FEL and pallet forks aerator ZD1211, RTV500
Apr 8, 2019
Seguin, Texas
I would agree 25 years ago when I got my first BX but now at 81 with some leg issues I think the step is great and I have a kubota factory step on mine , no I don‘t run a middle mower
Trimley
Jul 25, 2023
1,181
872
PNW-WA
I'm 62. With my past work history being laborious, the older I get, the more I'm reminded of that. Where I can, I plan ahead to make what I need to continue to do, as simple and pain free as possible.
leveraddict
Apr 1, 2019
905
594
NEPA
Old, both hips replaced over 20 years ago and knee replacement and bad back! Yeah I need a step on my BX! Especially after dirt work. On and off the tractor numerous times raking piles of rocks into the bucket from landscaping projects. Up and down up and down, uggh, Lots of rocks in NE PA!
5,188
"checkerplate"?
As in: "Diamond plate"?
Trimley
Jul 25, 2023
1,181
872
PNW-WA
yes, different name, same material.....
He knew what you meant.
