M7040 clucking in rear end when coming to a stop
Mikec575
59
Hello, I have a M7040 that was submerged under water for approx 30 minutes. I have changed all the fluids and replaced the rear brake discs. I have a clunkimg noise in the right rear axle/wheel area. It's started the clunking when on the brakes right before the tractor comes to a complete stop.
3,470
Made a mistake installing that brake disc…??
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
69
This might sound a little strange to you but you can try raising the cab mounts and putting a piece of rubber in-between the frame and cab tighten it back down and see if that helps. If it does you can replace the mounts
It could also be internal like swash plate or if that model uses electronic shif solenoids not sure would have to check wsm.
TECH101
Mar 8, 2022
69
Maybe you don't have a cab style 😜
