Rear Hydralics on a BX23S? Can I still use my back hoe?
Neighborbill
BX23S
Aug 28, 2023
Wisc
I've seen several videos and others on purchasing and mounting rear hydralics.
But, no one that I've come across said that if I put it on my BX23S, I won't be able to use my back hoe. Or, it will interfer while using it.
5,731
If you install an aux control valve in the BH supply line both will work just fine. On a BX23s,:
  1. Run pump to P on aux valve,
  2. Run PB on aux valve to P on BH
  3. Run T on aux valve to tank. You can do that by placing a tee in the BH return line.
Neighborbill
BX23S
Aug 28, 2023
Wisc
That should take care of the hydralic hook up to the rear. What about a kit? I've Summit?
5,731
Summit does not supply those types of kits but you can easily and economically roll your own using one of their P40 valves. The hardest part is determing were you want to mount the valve. Once you pick a spot the rest is just three hoses. Two rear remotes using one of their valves would be somewhere in the $300 - $500 range. Probably closer to the lower end.
Neighborbill
BX23S
Aug 28, 2023
Wisc
Thanks Dan. I'll look deeper into that.
