Broken blade.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
So while mowing Saturday on zero turn, cruising along suddenly it sounded like the entire deck was self imploding. I immediately turned off deck drove to the garage and found right outer blade was missing half its blade. I did not hit anything in recent memory and blades had been wire wheeled and sharpened around 3 or 4 mowings ago. At that time blades were visually inspected and no obvious defects were spotted. Has anyone ever had this happen??
The big dings in the half still there I believe are from the piece getting hit when it came off.
5,160
Hard to tell without seeing the broken edge but hard to imagine it wasn’t stress fractured from a prior impact. With something as hard as a mower blade fractures can be difficult to see on visual inspection prior to catastrophic failure such as you experienced.
If you look at the broken edge and see anything other than bright, shiny metal that would support a prior fracture that finally let go.
And no, I’ve bent blades, knocked chunks out of blades, but never had one break a huge chunk off like that. Seen a LOT of catastrophic metallurgical failures due to previously unknown fractures but not specifically on a mower blade. Can imagine that was a quite jarring experience.
Flintknapper
L2350DT
May 3, 2022
1,971
2,498
Deep East Texas
Never experienced a 'broken' blade on any mowing device in over 50 years of mowing.
Bent some, had large chips taken out, hit some pretty significant objects (enough to shear a crank/flywheel key). But have never had a blade actually break.
I can imagine the horrendous imbalance that would have resulted. Bet that was 'special'.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Special it was.🫨🤣Luckily didn't damage anything else. All new blades. All is good again.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Had one of the blades on my brush hog break at the pivot point. But I’ve hit more stumps and large brush than I can say. Things got pretty wobbly until I turned off the PTO.
lynnmor
B2601-1
May 3, 2021
1,645
1,419
Red Lion
If we could see the broken edge straight on then we might be able to determine the cause. Vibration and imbalance can cause fatigue cracks over time, it doesn't have to be a violent collision.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Blades are always balanced when sharpening. However I did have a bad hub a while back. Bearings were shot. That blade may have been on it and fatigued it. ????
Flintknapper
L2350DT
May 3, 2022
1,971
2,498
Deep East Texas
Yep, with a rotary cutter (Brush Hog) one blade can get knocked over the top of the other and become wedged there. It will nearly shake you out of the seat before you can disengage the PTO. :oops:
GrizBota
Apr 26, 2023
1,147
732
Oregon
Yes Sir. Been there, done that, got the T shirt.
5,160
Straight on pic
Not the most glaringly obvious example, but IMO the coloration strongly suggests that was cracked prior to the final failure.
Lynnmor is certainly correct that vibration can cause stress cracking so it could have been from excessive vibration over time. Also could be from a prior impact, or possibly from damage caused in manufacturing or shipping.
If it was vibrating enough to cause fracturing from fatigue, I would expect the operator to pick up on that as it would have to be pretty significant vibration. Can’t totally rule it out, though.
Manufacturing defect isn’t totally excluded either, but unlikely based on the extreme rarity of this type event. The glaring weakness of that argument for exclusion is it’s basis in anecdotal evidence rather than real research.
Impact starting a crack that may have progressed due to normal stresses of use until it failed: given the normal use of a mower blade, that would still be my strongest suspect. Potential fractures that are undetectable without testing that isn’t cost effective on a mower blade is the reason if you ever hit something hard enough to bend a blade it should be replaced rather than bent back and put back in service. Argument against prior impact would likely be it wasn’t bent and didn’t have other indication of severe impact when it was recently serviced.
That’s my opinion which isn’t worth much.
5,782
so the 64K$ question...
did you FIND the missing half ?????
Knowing Mr. Murphy, if you haven't, you will ,in a rather bad way........
When you do, take both pieces to dealer, ask the parts person what glue to they sell to put them back together...... after the laughs, maybe,just maybe, they'l cut you a deal for a new blade.
I'm just happy nobody got hurt when '1 became 2' !!!!
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
Actually in corn field somewhere. Maybe find it the fall. 30 seconds earlier it would have hit, or gone through the side of the house.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,612
2,077
Western MT
What brand/model is your mower?
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
457
244
Randolph county N.C.
Not a metalurgist so FWIW. Based on picture in post #8. I wonder if that blade was a little loose and the compression washers spun creating heat in that area. It looks like a color change in the metal where the washer would contact the blade.
Ktrim
Dec 23, 2020
444
369
Nazareth Pa
I see what you're talking about but all was set and tight. Rechecked torque before removing bolts. ?????
