AC only blowing out of one side
Okaggie
M6060, M8580, Landpride box blade, RTV
Feb 24, 2023
Oklahoma
I was moving hay bales and noticed that my ac was only blowing out of right side on my M6060. I removed the intake filter at the rear of the cab but did not make any difference. Any ideas of what could be wrong?
Maybe a mud dauber nest in the venting somewhere?
5,257
1,046
It sounds like you do not know of the second cabin air filter which is outside located under the overhang of the roof on the left rear.
This may not be your probblem but it is a filter which picks up lots of stuff in the air around the tractor.
The condenser located in front of the rad needs to be cleaned.
Am I correct in thinking you did not buy this machine new and did not get any manuals?
5,257
1,046
Another question:
Does the system respond to the "Mode Motor" This is the middle knob on the AC control panel which directs air out different outlets.
Okaggie
Feb 24, 2023
Oklahoma
I did buy the tractor new and have an operators manual. I cleaned the fresh air filter(not too dirty), the in cabin filter (pretty dirty), and blew out the condenser coils and the radiator after removing and cleaning the screen for each. It blows cold air but mostly out of the right side. The mode switch works fine. Sends air out the vents or defrost or both. Just limited air out the left side.
Okaggie
Feb 24, 2023
Oklahoma
Okaggie
Feb 24, 2023
Oklahoma
Update: using a flashlight I discovered a huge pair of mud diabetes nests blocking the left ducts. Got those out and she blows good now. Guess I’ll have to quit leaving my side windows cracked open.
5,257
1,046
Thanks for the update. A number of people were suggesting this cause.
