Fork extension question
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,435
1,728
Kalamazoo, MI
I think I'm going to Fab up some fork extensions for my pallet fork attachment. Thinking between 6 and 7 feet long, not planning on super heavy lifting, more for helping balance lighter, longer loads.
Tubing or channel? Post ideas and pictures please!
mcfarmall
Sep 11, 2013
1,435
1,728
Kalamazoo, MI
There are pre-made fork ext. Rectangular tube not outrages pricing
😁 I'm a make/builder by nature. I'm pretty hard to please with stuff made by others/store-bought. We have fork extensions at my employer but I think I can make a set =/> them.
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Heavy channel. I bought a set of extensions a few months ago at an auction but they were made with plate steel so they could be a tapered channel. The top and bottom plates were cut, then the tapered side plates were cut to taper. Then they were welded all the way to make the tapered channel. These are ten foot extensions thatI use on my Woods pallet forks to move a 8x8 chicken coop and 8x15 run. Work like a charm, nothing bent or broke.
I’ll take pics when I get home tomorrow and post for you.
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
260
143
Agua Dulce, California
Totally understand just today finished annular drilling over 200 5/8 holes in a 3/4in plate welding table.
Yooper
3901 LA525
May 31, 2015
1,657
802
NE Wisconsin
Either way will work. What you will run into is the extensions sliding off when backing out. Think of some sort of strap or chain to prevent this and you will be happier with your forks
Jasonized
L3902, LA526, box scraper, grapple, pallet forks, tree ripper, lane shark 3
May 16, 2023
140
34
California coast
Mine are open channel extensions, with a bar welded across the back. Probably the most common type…. To put them on, lift up at an angle and slip them to the back. Setting them down flat moves the back bar up behind the bend in the actual forks, and keeps them from sliding off. Just make sure you have the right distance so they don’t bind.
5,775
I had to move some 9by12 wooden sheds one day, rush job....super RUSH job...one of those HAD TO BE DONE, NOW jobs...
..grabbed 4, 2by6-12 feet long and screwed them together, then made 2nd fork extender.
They worked surprisingly very well and at the end of the job,took them all apart and back onto the shelf.
Jasonized
May 16, 2023
140
34
California coast
Yep! That’s the main reason I got the extenders…. I have a 4x8 bee house. I’d like to move it, but the standard forks are 42”…. Sigh. So, 60” extensions…
if I hadn’t found the extenders, 2x6 (or 8) were my next choice..
