Anybody buy and install their own mid-mount mower deck?
aspic911
B2301
Jun 19, 2023
Hello,
Has anyone bought a mid mount mower deck and installed it them self?
I have a B2301 and want to buy a mower for it I am not sure how difficult it is or need to know info.
Thank you for any help!
GrizBota
Apr 26, 2023
1,147
732
Oregon
I haven’t. The MMM was mounted to my B2601. I did have to adjust it a fair bit, since it wasn’t set up correctly. I’ve had it off and on a couple times. If you can find the pdf operators manual for the MMM, it has all of the mounting directions in it. That may help you appreciate what you’re getting in to.
jyoutz
Jan 14, 2019
3,383
2,425
Edgewood, New Mexico
It shouldn’t be too bad to install if you buy the correct mowing deck for your tractor. No different than the continual on/off process you’re going to have to get used to with a mmm.
SDT
multiple and various
Apr 15, 2018
3,311
1,102
SE, IN
I bought a pre-owned but nearly unused 72" deck for my B3350 a year or so after buying the tractor simply because it was such a good deal and used MMMs are difficult to find. Installed and set it up myself then removed and stored. Still haven't used it.
Comprehensive installation and set-up instructions are in the mower (not tractor) Operator's Manual.
If you follow the instructions precisely and do not take short-cuts, things will work out as intended.
A level, concrete floor is just about mandatory for proper set-up.
aspic911
B2301
Jun 19, 2023
Thank you for the replies.
I am looking for the PDF manual to get a better understanding of how it goes on and works.
My big fear is i have to travel a ways to get the deck and i want to make sure I do not need anything else for the install.
SDT
Apr 15, 2018
3,311
1,102
SE, IN
Valid concern.
There are many brackets, etc., necessary, all of which are expensive if bought separately.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
352
139
St. Louis, mo.
Check my profile if you’re within driving distance I have a RCK60-32 which is the correct mmm for your tractor
aspic911
B2301
Jun 19, 2023
Thank you for all the input and help. I found a guy on youtube (Ryan lynch) who showed how to assemble a deck on a B2401. I think I know what i am getting into now.
