Hi,
I have owned a B7001 tractor from 1977.
Its in very good shape and the engine runs perfect.
The dealer put in a new battery - so in the beginning no problems at all in the beginning.
Now the battery was getting weak. I measured 12.1V.
I charged the battary with a charger - 14V - the battery is back again (13.2V) and everything works fine. The Battery is ok.
When I measure the battery with running engine on max RPM and full lights on etc. The Voltage is sinking below 12.4V and is sinking slowly as it is typically with lights etc on.
The Battery is not charging. But i can see a bit variation in the voltage at different RPMs.
So I measured in AC the Dynamo. Its only 7-12,9V comming out of the dynamo depending on the RPM.
I think 50% from the Stator is damaged. Does anyone ever rebuild a stator for such a dynamo? How are the stator coils wired? Does anyone has technical data for this?
I can't find a spare part here in Germany - so the only laternative would be shipping from the US at some dealtes I found the right spare part 15372-64290.
Thanks for all comments and help.
Best regards,
Mario
Best regards,
Mario
