M5660SUHD vs MX6000
WillyBill
M5660SUHD, LA1154SU w/3rd Function
Mar 25, 2021
72
41
Northwest Tennessee
Anybody else compared these 2? What are your thoughts? What prices were you quoted for financed O/S tractor, loader, 3rd function?
PaulL
2,650
1,635
NZ
I believe the M is noticeably bigger as a machine, and more capable. Loader in particular I believe. If you can live with the stripped down model M (i.e. no functions removed that you need), it's probably better buying.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,441
1,735
Kalamazoo, MI
I did. Went with the M5660 and LA1154 loader. I'm ok with the hydraulic shuttle transmission and fewer bells & whistles.
WillyBill
Mar 25, 2021
72
41
Northwest Tennessee
Thanks for the feedback. I searched and found a couple of comparisons. The M is heavier, more rear lift capacity, little bigger loader, supposed to be more of an Ag utility vs. compact utility. I was quoted close to same price for the two.
9,958
I have an MX6000 and M6060. I like the MX a lot and it's not going anywhere, but it's not an M that's for sure. If you don't care about the HST and you want an open station then the M5660 is the way to go. Way more tractor.
GrumpyFarmer
4,486
Yeah…What MCMXI said….it’s more tractor for sure and maybe better value for dollar too? I looked at an M when I ordered an MX…for me it came down to HST as a priority for spousal unit safer (note I did not say safe 🥶) and more likely use of it. I just could not come to terms with having spousal unit slip of a pedal or something. It never came to price…it was just dreaming and drooling. On an open station to me an M offered more weight and a little more width which means more stability. Plus it can lift a good bit more on the rear and ultimately move more safely all the way around. Personally if I had your money or MCMXI’s money I would burn mine and I’d probably have an M4 for sure 😂. Just kidding gents, but an M or M4 are sweet rides any way you look at them.
Wyatt545
Kubota M5660, RCR1884, pallet forks and EA Severe Xtreme 84" box blade
Nov 13, 2022
Zionville, NC
I thought for sure I was getting MX6000 cab; however, I went and looked at an M5660 and went with 5660. WAY more tractor and I’m quickly falling in love with it. I’m sure the HST is nice at times, but I really like gear drive tractors, larger tires, increased weight and lift capacity
WillyBill
Mar 25, 2021
72
41
Northwest Tennessee
I drove the M5660 yesterday. The salesman said use clutch when using the shuttle shift. Sales brochure said no clutch. I haven’t seen the manual yet. What’s the correct way to use the shuttle shift?
Wyatt545
Nov 13, 2022
Zionville, NC
Wyatt545
Nov 13, 2022
Zionville, NC
I don’t clutch when moving around in low range and low RPM; however, when mowing or other higher RPM and/or high range, I use the clutch when shifting F & R.
Now what defines slowly, is anyone’s guess. HaHa!
WillyBill
Mar 25, 2021
72
41
Northwest Tennessee
Thank you very much Sir. Where did you find the digital version of the operator’s manual?
Wyatt545
Nov 13, 2022
Zionville, NC
My Kubota App. I keep up with all maintenance and materials there. Easy to use.
9,958
The shuttle shift operates the clutch pack hydraulically so there's no need to depress the clutch pedal when changing direction. I only use the clutch pedal when shifting gears (within a range) or when backing up to an implement for more control.
I do allow the rpm to drop to near idle when shifting the shuttle between F and R. Engaging the clutch via the shuttle shift or via the clutch pedal with the rpm significantly off idle isn't a good idea. We're not trying to launch these tractors off the line like a drag race.
Borane4
M4-071
Dec 16, 2020
105
I have an M4. For F>R shifting, I never use the clutch. Sometimes I do shifting F>R. The limit for me is in higher gears like 5L, 6L the electronic clutch let-off is pretty abrupt and will launch you backwards. I dont think its a problem for the system, it's just a quick launch backwards and is unsettling acceleration. Going R>F is less abrupt for some reason, or maybe stabilized by the weight of the FEL. It could be a mental thing...like fear of flying backwards into something.
WillyBill
Mar 25, 2021
72
41
Northwest Tennessee
Thank you all for your comments. I bought the M5660SUHD with the R1-W tires yesterday. Getting a Kubota 3rd function, wheel weights and a right fender handgrip added. I’ve had a B7100HSTD without an FEL for 27 years. Looking forward to a bigger tractor. And an FEL!
9,958
That's awesome and congratulations! You will really like the M5660. I like the Kubota 3rd function kits. You got two sets of rear remotes right, or at least that's what I got on my 6060 and I think that's how the M series come.
Also, you might want to look into a bolt-on cutting edge if the bucket didn't come with one. The bucket on the 6060 didn't have one, or any holes to add one, but I was able to move the factory edge from the MX bucket to the M bucket since I had bought an EA bolt on cutting edge as an upgrade for the MX.
WillyBill
Mar 25, 2021
72
41
Northwest Tennessee
Thank you Sir. Only one remote came on the M5660. I will check into adding a cutting edge.
9,958
You might know this already, but you can buy a bolt-on straight edge from Kubota that is intended to just protect the leading edge of the bucket, or you can buy more aggressive cutting edges from companies such as Everything Attachments, BXpanded and perhaps some others. If you don't intend to dig with the bucket the Kubota edge is sufficient, and it's a lot less aggressive if you're putting the bucket down on asphalt or concrete.
gregg l
m5660suhd
Dec 5, 2023
Singer, louisiana
Purchased an M5660SUHD 5 years ago. Wanted a tractor that was Cat II and 2000 lb loader capacity. Needed something that could be used in barn yard areas but also get out to do heavier jobs. It has 1100 hrs now. No problems. About 300 of the hours were grapple work after a couple of hurricanes. Used for mowing in wooded areas and other general tractor work. My only complaint is the DPF regeneration. But that's just part of having any newer tractor.
