3pt hitch snowblower cross shaft bearing replacement
3400 kubota
2005 L3400, Landpride GS1572 land grader, Wallenstein BX62 wood chipper
Dec 21, 2022
11
Ottawa, Canada
Hi, I have posted here before but had to re-register. I have an 05 agro-trend S 72 blower on my L3400 and I have to replace the cross shaft bearing/flangette. My question is do I have to remove the cross shaft or does the shaft split at the shear bolt and pull apart.
Thanks,
J
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,441
1,735
Kalamazoo, MI
Are you working on the tractor or the snowblower? I'm not familiar with shear bolts on the 3 point hitch.
rogerius
Kubota
Mar 5, 2023
firuta911
Thanks,
J
Did you change the bearing? Just had same problem with mine and now I'm looking for bearing. Could you share the bearing part number?
