L175 again.
JerryMT
Jun 17, 2017
529
153
The Palouse - North Idaho
Won't start. What compression tester do I use? My automotive one won't work. The air cleaner isn't connected.
You need to get a diesel compression tester and if your compression is less than about 350 psig, you'll need to find out why. Valve adjustment, burned valve(s), bad rings, burned piston crown, blown head gasket, etc
2,027
Supposedly Harbor Freight has a gauge set that works with an adapter for the glow plug hole or the injector holes.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
You’d be better off posting questions like this in the initial post since you’re dealing with the same issue. I believe you now have all the facts spread out over 3 different posts.
pigdoc
G1800S L2500
Aug 19, 2022
303
231
SE Pennsylvania
Russell, I think you got your words out of order.
"Harbor Freight has a gauge set that supposedly works...."
There, that's better.
<rimshot>
-Paul
2,027
<rimshot>
-Paul
Your statement supposes the gauge will work but Harbor Freight has it.
Since I am not sure that Harbor Freight was the correct store, I only supposed they were where to look
My word order states my thought correctly, yours doesn’t.
But it is no big deal either way.
ferguson
L3130
Jan 19, 2022
316
122
w.v.
Have the harbor freight comp.tester / Works on my L3130 through the glow plug hole
