3 PONT HITCH WON'T LIFT
Stomps
B6200D, Mustang 2040 SS
Jul 17, 2022
10
Lewistown, PA 17044
Hello friends, I have a B6200 that last year was working fine. I don't use it very much and plan on selling. But now won't lift the 3 point hitch arms. I havee changed the filter and checked the hydro fluid level. Thanks, in adance for any help.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I hope someone who knows something responds. I have read of some interaction between the three point lift and the blade deck lift, I think. Check your owner manual, there may be a lever to flip to select between them. I think it varies by model.
DJDD
2022 BX2680, LA344, LP RCR1248
Oct 31, 2022
Prattville, AL
I had a similar issue, there's a dial underneath the seat for the 3 point hitch pressure. I inadvertently turned it all the way down one day. Check and make sure a kid hasn't been turning knobs.
3,392
Pretty simple machine. There is a diverter valve on the right side just under the pump. If it is in the wrong position your lift won't work. Consult the owners manual for a description of the "hydraulic outlet block".
Any hydraulic options or loader on the machine?
Stomps
Jul 17, 2022
10
Lewistown, PA 17044
Thanks. There was a lift circuit for a blower. I disconnected it a good while ago and the arms lifted just fine until recently. I'll let you know after I check it out.
Stomps
Jul 17, 2022
10
Lewistown, PA 17044
Thanks. I'll let you know after I check it out.
3,392
On that machine it is going to be real easy to check for flow and pressure.
