Hydraulic leak from 1880 FEL stick.
tomatthe
BX 1880
Oct 27, 2022
North Carolina
I noticed a small drip on my mowing deck, and looking above it seems to be coming from the 4 lines that run up to the stick control for the FEL. Its a 2021 1880 bx tractor, and the lines here are shielded by a metal brace, and then the wheel/tire make it basically impossible to get to. It only drips a bit when the fel is under load. I can't really tell what the proper approach to actually get at the connections is to check/tighten them. Any advice would be appreciated. I'm not 100% sure which line is leaking as it only happens under load and don't want to get near the leak when it has pressure.
5,386
You have 7 hydraulic lines at the valve - three hoses with SAE/JIC fittings and four steel lines with banjo fittings Any one or more of them could be leaking. Its buried up under the fender pretty good - taking the wheel off might give you a better view. I would think worst case the fender may have to come off to access some/all of the fittings. Hopefully not - that looks like its a one piece assembly.
tomatthe
BX 1880
Oct 27, 2022
North Carolina
Thanks for the nice diagram, it is very tight in there and that's a pile of fittings to try and find a leak. Tractor has less that 100hrs on it, bit frustrating but this looks like it might be out of my realm.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
193
76
Waterford, Maine
Messicks says if you have small leaks around the tractor and loader, it is normal. I also have the 1880
tomatthe
BX 1880
Oct 27, 2022
North Carolina
What is the actual warranty? I was under the impression that wasn't an option. I bought it 2nd hand, but it had 38hrs on it when I got it. I'm pretty sure its a 2020 model. I'm not rushing to fix the issue as it is a very small leak and only when under load, but I also don't want ot just ignore it. I really think if I could access things easily its probably just a loose fitting.
xrocketengineer
Nov 14, 2020
800
722
Merritt Island, Florida
If you bought it from a dealer, call them with the serial number and they would be able to tell you if there is any warranty left. Mine had when new, 2 years "bumper to bumper" (as they called it) and with the finance deal 6 years on the powertrain.
