Good morning folks, new member here. Recently got an L2850DT for a project after I'd sold my old MF30B. I needed 4wd. Anyway, it starts great, when it starts.
Recently it's taken to not starting at all. Lights come on the dash but no sound from the starter. Only sound is a relay under the front of the fuel tank so I'm thinking it's probably the timer relay engaging.
I've tested the neutral safety switch per the WSM & it reads 1.4 ohms resistance when the switch is pressed. That should be 0 (zero) ohms so problem #1 identified. I thoroughly cleaned & brightened the battery posts, battery cable clamps, ground connection to the chassis & the negative cable, & all three lugs that bolt to the bottom of the starter.
I haven't tested the voltage & resistance of the ignition switch yet but plan to. So, with all that said, here's my question.
Where is the fusible link supposed to be? The wiring on this has been, well, reworked/patched/etc... from the workshop manual (WSM) it looks like the link should be immediately in front of the starter but all that's there is cable with electrical tape wrapped around it. The wiring diagram shows the link somewhere between the starter & the ignition switch. Anyone with this model (it's the later generation of serial numbers) that could post a picture or shed any light on this would be greatly appreciated. I'm trying to avoid the cost of a whole new wiring harness if I can avoid it. Thanks!
