Pallet forks would be helpful
JeremyBX2200
BX2200
Aug 3, 2020
503
453
Indiana
I have the Landpride set. Wasnt happy at first but they have grown in me. I use for a few things beside the actual forks. Just completed adapting my 6 ft Polaris snow blade ti the backrest. Top link in lieu of winch. I recommend a set, i actually looked at the Titan ones for the price and material. Landpride are ok but not much more sturdy. Have a safety cage to to skip.ladders. My point is they are very handy to have.
Looks like they are pretty versatile setup. I like the safety cage idea, but your tractor is a lot bigger than mine.
Ridelght
2022 Kubota L4060 Polaris Rangerxp800 Ford 3400
Feb 16, 2022
434
296
Yeah but still id recommend. Mine is L4060 but your at 22hp. I hate buying a single use item. The snow blade is because ill sit my old butt in the heat and cab. Im sure you could find a lot of uses to. Bang for your buck. I also have tongs instead of a grapple to move logs.
xrocketengineer
Nov 14, 2020
800
722
Merritt Island, Florida
I got my BX1880 with a pin on bucket because of the extra weight of the SSQA and the limited lift capability of the loader. So this is what I did:
For the adapter:
For the forks at the time a better deal:
I already had the SGC0548 Grapple that I bought with the tractor.
Snowman7
May 20, 2020
388
281
Boyne Falls, MI.
For the adapter:
I have the Redline unit on my LX, I dig them
5,707
yeesh, that add-a-grapple weighs just over 200# so would SERIOUSLY reduce the actual 'payload' on my BX23S to where I might as well get off tractor and carry 'stuff' by hand.
It would be nice on tractors with 1000#+ loader payloads though.
Sep 3, 2022
51
29
America
I've not seen a three point setup like that, was it a kit? Looks like bolt on. I've been wanting a SSQA to 3pt with hydraulic motor so I can run them on my skid steer (post hole auger, brush mower, etc.).
BXHoosier
BX24
Jan 21, 2018
493
574
Indiana
A set of forks that hook over the top lip of the bucket was the first thing I built for my BX. Later on, I built a pin on frame that also has attachment points so that it also fits onto the 3-point hitch. I now have the option of using my forks on the bucket, with the frame on the loader, or with the frame on the 3-point.
Reactions: 6 users
Ridelght
Feb 16, 2022
434
296
I fabricated it. Plow was for UTV hung from below. I used clevis mounts to create 3 points to connect. Then made the lowering frame to get mounted the same way. Used Stabilzers I had for my old Ford Tractor. Bolted up Then Welded after checking to be sure I can still mount to the utv if I want.
That is a cool item in the picture !!!
