hello, I have a problem with my manual kubota L2850 dt
juan
kubota l2850
Sep 14, 2022
miami fl
hello, I have a problem with my manual kubota L2850 dt, I have had problems with the hydraulic system, I changed the hydraulic oil, with kubota super udt2, and the hydraulic system works 10 minutes, and then a sound starts in the hydraulic pump, and I have been doing some research on the viscosity of the oil and the temperature, I live in miami fl. sometimes it's 100°F. Should I use an oil with a higher viscosity grade? I appreciate any advice or recommendation thanks
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
The viscosity of Super UDT2 should be correct for summer or winter use. Here summer temperatures are rarely over 115 and there's no issue. Try changing your hydraulic oil filter and see if there's some kind of screen in the system which could impede flow.
Flintknapper
L2350DT
May 3, 2022
1,971
2,498
Deep East Texas
Agreed.
Replace hyd. filter and remove and clean the screen strainer (something folks often overlook).
5,652
Viscosity of the oil is fine. What sort of sound are you hearing and are you sure it is coming from the pump?
juan
kubota l2850
Sep 14, 2022
miami fl
I changed the pump I put a new one .. it is a sound in the line that goes to the front direction
juan
kubota l2850
Sep 14, 2022
miami fl
Agreed.
I'm not an expert on the subject of hydraulic oil...but I found this information. with respect to oil viscosity and ambient temperatures.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
The suction hoses tend to be a problem as these units get older. They can crack or get too hard to make a seal and allow air in. Part # 040 . Don’t forget new clamps if that’s the issue… part # 050
