ATV x1100c - What are these pre-wired plugs intended for?
reindav
ATV x1100c
Sep 9, 2022
KS
I installed a radio in my 2022 x1100c and am wondering what the other wiring in the radio compartment
is for exactly...
I would also love to know what the two plugs at the rear are for...
Thanks in advance for any knowledge provided!
The_Wingnut
Grand L4060, ZD21, ZD28, ZD331, RTV X1100C, Branson 3820, JD 1020, JD 50
Dec 8, 2021
91
Tyner, NC
Can't help with the plugs but I do have a question about your radio install. I installed one in my 1100 too. Can you see the radio face, so you can tell what radio station you are on? Maybe I installed mine wrong but no way I can see the face the pre-cut radio hole is not angled down and the radio is parallel with the headliner.
3,859
2,497
Rear end might be for a backup alarm.
Look at the connectors and count pins to get a better clue of what's what. Big wires, small wires,...
WSM helps you decipher what's on your harness. Unfortunately K stopped publishing wiring schematics in the owners manual on my xg850 so I bought the WSM.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,457
473
Are they pre-wired for the beacon light maybe? I never ended up getting the beacon since I only low my own property.
I can't see my radio display either Wingnut unless i kind of stand up in cab and look at it.
reindav
ATV x1100c
Sep 9, 2022
KS
Yep, the radio display issue could have been easily fixed if Kubota designed the opening to be angle down
a bit. I have to just about stand up to see it.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
Two of them are for front and rear work lights, and the plugs are inside the roof for the lights.
