Wanted backhoe for b7100
bikerdib
L4701 with FEL, BH92 backhoe
Oct 5, 2010
210
14
Wallis, Texas
I'm not sure they ever made one for the B7100, can't imagine it would have enough flow in the hydro system. There is the option of a 3 point BH with a hydro pump running on the power takeoff. But, I wouldn't recommend a 3 point BH, they are tough on the tractor. In fact, people have torn their tractors in 2 with them
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
442
179
Attalla Alabama
mossycreekoutdoors.com
They most certainly did make them. Even for the b6000. Yes I understand how the hydraulics work on the 7100. Yes I agree 3 point is not the way to go. Thanks for the response
3,253
There is the subframe mounted, PTO powered B670.
But they are pretty rare, and usually beat up.
I have this one, and another that is so bad it is essentially an ugly parts pile.
5,183
B7100 specs show a hyd. flow of 3 gpm.
A 16 HP tractor is a mighty small machine to support a backhoe.
At a minimum, it would seem that a significant flow PTO pump would be necessary.
5,183
3,253
Thanks!
The B7100 was pretty decent when I bought it, but the hoe needed a lot of work.
Here is a compendium of the work usually required on these, as a few of us discuss & compare notes on the rebuilds.
It is a long thread, but tons of good info & pics on this hoe & what they usually need:
Think you can you make the Hanix look that pretty?
Unless I win the lottery so I can buy a high capacity hot water pressure washer, I doubt it.
The parts that I have to clean up to do machine work on will probably get repainted, but it is just too grubby to mess with. If I have to clean the whole machine the way I have been cleaning small parts & assemblies, it will cost me another $10K in solvents, brushes, soaps, scrapers, gloves, paint, and such, plus another year in labor.
My Barn
Kubota, Ford
Sep 14, 2022
135
37
I know it's a long shot but looking for a backhoe for a b7100. I'm in Northeast Alabama. Will travel a little or can maybe work out shipping. Thank you
We have a B8200 with factory backhoe. I believe Kubota had Woods make (4520) it for them? The Kubota has a two speed PTO. I have used the backhoe for removing tree stumps, water and electric lines to my barn. It strong enough for most jobs around the farm etc.
