Off center zerk
Cayuga
Kubota BX23S, JD 214
Mar 28, 2021
19
Lansing, NY
Hi,
I was greasing my tractor (BX23S) and discovered that once of the zerks is "off-center" and I can't get the grease gun to connect to it. This is the 2nd time that I've greased the tractor and I'm pretty sure that I greased this one last time, but I have a new grease gun now.
I have some pictures and I'm looking for suggestions. Should I somehow repair/replace it? Should I get an extension which might be narrower? ???
Thanks in advance for any suggestions!
Jeff
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
I agree. It's probably bent or cross threaded. Get a new fitting and hopefully the threads aren't ruined and it will go in straight.
Cayuga
Mar 28, 2021
19
Lansing, NY
Thanks - I'll try that. I had unscrewed it and pulled it out and it looked OK to me, but I'm still a novice.....
3,396
Look at the hole, if it is off center or tapped crooked, replace the pin.
AND if new, get the dealer to supply the replacement pin.
Did you buy the tractor new or used? Mentioning greasing only twice prompts this question...
Edit: I meant supply the replacement pin. Sometimes a repair you can do yourself is much cheaper time wise than getting the warranted tractor back to the dealer for repair.
Cayuga
Mar 28, 2021
19
Lansing, NY
I bought it used with about 45 hours on it.
It has an extended warranty (through 7/2024), but i'd have to pay someone or rent a trailer to get it to the closest dealer about 30 miles from here.
Cayuga
Mar 28, 2021
19
Lansing, NY
I'm trying to find the part number for the pin (BT603 backhoe). Does anyone happen to know it?
Crash277
BX23S
Jan 17, 2021
844
623
warranty might cover a service call. dealer has been to my place with no cost to me a few times.
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
329
94
Bagley, MN, United States
Illustrated Parts List
Click on ‘View Illustrated Parts’
Click on ‘I accept the Term and Conditions’ BOX then click on ‘open’
Enter your model – click on search
Click on your exact model
Click on ‘Parts’ for Model Parts Menu
Click on ‘Option Model’ for Attachment List
Click on desired attachment and a new tab is opened
Click on ‘Parts’ for Attachment Parts Menu
4,204
First things FIRST. Pull the pin, examine to see if the zerk-hole is “centered” and if you can simply replace the zerk with another that is not “bent” or cross-threaded.
Zerks can be SAE or Metric. Many Kubota accessories (front end loader or backhoe etc) are made in the U.S. and have SAE parts. Some items are made elsewhere …or have Metric for various reasons. You’ll have to determine THESE THings before you jump to calling in a dealer for “warranty” work on a pin.
5,187
"Warranty" work on the pin should be relatively simple.
The OP could remove the pin, and take the pin to the dealer for replacement.
Too difficult for the OP to remove the pin, or have a friend remove it for him?
Using a needle grease gun tip for just that fitting would be the easiest solution.
3,396
Just to add something...in my case when I pull a pin, I have another pin available to slip in from the other side when the pin I want out comes out.
The reason is to hold things in place that might shift when the pin comes out.
Just what I do, and have had no issues doing so...Just think it could be a nightmare trying to realign things if things shifted when the original pin came out.
Then reverse the procedure when the original pin or a new one goes in.
Works for me...
4,204
Perhaps I’m misreading you…. but calling the dealer for warranty …for a zerk damaged by the owner…. would be a silly thing.
First things FIRST….. means to examine the pin and zerk to see the problem ..before embarrassing yourself with the claim you have a “warranty” problem. If the operator crammed a grease gun onto the zerk with a too-tight grip on the gun-end…and then “Pried” the gun loose from the zerk with a hard side-ways action …thereby bending the zerk or ripping it from the threads…. it won’t likely be a “warranty” item. Warranty would not likely include abuse.
Either way, pulling the pin…. the first thing I suggested…. would probably / hopefully make it OBVIOUS that taking it in-hand to the dealer would be a simple thing to do.
5,187
The issue being discussed is not about "you" (me), but is for, and about the OP.
3,879
2,399
I'd be amazed if the hole were off center. And those fittings are recessed to prevent getting broken.
Cayuga
Mar 28, 2021
19
Lansing, NY
Update. I pulled the zerk and it looked fine to me (see picture). The hole in the pin also looked fine to me. I suspect that the previous owner somehow cross threaded the zerk. With a little bit of strong love I was able to screw the zerk back in centered :). All is good for now and I have some ideas about what to do if this eventually fails.
I like the idea of a "placeholder" pin to keep things from shifting when replacing the pin - I was thinking the same thing - it's nice to know that I wasn't crazy :)
Thanks to EVERYONE for the thoughtful/helpful suggestions.
Jeff
Tughill Tom
B3200
Dec 23, 2013
1,474
2,157
Turin, NY
Just an FYI, I bought a Lock & Lube fitting for my gun and it doesn't fit in the recessed grease fittings on my Woods BH. No problems on the FEL.
Jeff
Cayuga
Mar 28, 2021
19
Lansing, NY
Tom - that might have been why I didn't have trouble the first time I greased the tractor. My old grease gun had a "standard" fitting, the new one has a lock-n-lube fitting.
Tughill Tom
B3200
Dec 23, 2013
1,474
2,157
Turin, NY
Sounds like that's it. I switch in-between them now.
