Not related but trying to figure out how to do this posting thing. No response on previous attempts to "start a conversation " Hydraulic fluid periodically leaking from the split pin plug under clutch housing. Any one out there Experienced this?I'll give it a try. Your blue wire should be connected to the Battery cable at the starter. Might be the black wire hanging free? Your yellow that I don't see other than at the relay should be going to the starter solenoid that is currently plugged into the blue wire. The white ground and the red trigger from the original start circuit appear correct.
