Loud clicking sound from loader BX2200D
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
232
250
Pennsylvania
I was leveling stone today behind the tractor shed, seems every time I set for float mode there is a very loud "click" coming from the loader....is that normal, seems too loud for that. Almost sounds like the loader will self destruct.
I looked around all the connections, seem fine, don't want to break this tractor, need to get a lot of chores done. Could it be the deck hitting the frame ? I just put that on a couple weeks ago.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Make sure to check all the pins holding the bucket and cylinders on. Possibly something became mis aligned..
Only in float mode??
Edit: re read post.. could a rock have found it's way into one of the pivot points?
arml
Jan 27, 2022
232
250
Pennsylvania
Thanks for the reply, I'll look it over very closely. I did notice that it also does it now when doing down pressure in reverse.
dlsmith
BX2230, LA211
Nov 15, 2018
1,302
919
Goshen, IN
Did you check the loader mounts that bolt to the frame to make sure one of them isn't loose?
arml
Jan 27, 2022
232
250
Pennsylvania
What is the torque spec for the main frame loader bolts ?
lynnmor
B2601-1
May 3, 2021
1,667
1,448
Red Lion
Get the bolt size, remove one if necessary, then get a torque chart that will show the specification for each type of bolt.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
If you greased it did you see it oozing out of every joint you greased? If not try again and don't miss any of the multiple ones it has.. look high and low.
I just used mine after sitting for a month and a half and it made a pretty good click/creak/pop noise.. I'll be greasing er up next time out there.
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
210
183
Westford, Massachusetts
shelkol.com
I checked with a breaker bar and, a pipe for leverage.....it's well past 3 grunts. That noise has me worried, guess I'll just keep searching.
Get someone to operate the loader while you watch. Hopefully you can pinpoint where the noise is coming from
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Tractor data.com says 19 years old at youngest for BX2200 so I suspect pin slop in loader.
