Folks - 45 years in the industry tells me my disc is hanging on the input shaft OR I'm missing something obvious. Since I have no pilot bushing - my experience is telling me - Tractor starts cold, clutch has .75 inch free play at pedal before release bearing contacts clutch fingers, I can feel the pressure plate releasing about 2.5" of stroke with more to go if needed, no funny noises, everything works great. Start to mow or get the rig warm not hot just warm and come to a stop with the clutch and it creeps, if I hit the brake it will stop the tractor but depending on how warm it gets, the problem gets worse. Cold, I can push clutch in and engage PTO, warm I must shuttle into forward or reverse to stop input shaft from spinning, then engage PTO. Question is I've heard they can strip splines - is this the beginning symptoms? Could it be rust on the input shaft - the unit is garaged and although I put a lab scope in the bell housing, it looks clean, no oil leakage, dust, debris, etc - looks great. I am getting ready to pull starter and use lab scope if possible to get a look at the clutch splines. Any input would be appreciated - its useable but I'm afraid something may come apart and grenade my world... Thanks fellers!
UPDATE: 6/5/12
Remove starter and clutch linkage, retracted release bearing fully and gave a good look with lab scope, splines are clean, no oil or grease, all fingers on pressure plate equal distance from release bearing. Re-assembled and same issue, cold clutch releases fine, pto engages and stops when depressing clutch, no forward or reverse creeping. Get it warm just idling, depressing clutch does not fully release, pto spins when clutch is depressed and shuttle forward or reverse, machine creeps - anybody - idea's?
UPDATE 6/5/12
Talked to local Kubota dealer - as stated above I have over 45 years experience, so while remaining open minded, I pity some of the folks who must deal with these people. First I was told it was most likely in the GST system, I explained it had a single stage clutch that disengaged the PTO and main drive, how could anything pull the tractor and spin the PTO - IF the clutch was releasing. After going the third tech on the phone, he agreed it would seem the disc is not being released and or hanging on the splines - however he was unaware of any issue where splines were being stripped. I mentioned I had read information on the web, indicating issues and re-designed disc (not sure if stripping was the reason), still he was unaware of any TSB or issues.
I'll most likely wait till winter to tear is down but my thoughts are IF the disc could be in the early stages of stripping / rolling the splines, perhaps as the input shaft heats / expands the rolled edges of a failing spline may be hanging disc. I can think of no other reason the warming of an engine would cause a clutch to drag. I know many other issues could be at fault for a clutch not releasing all the way but from startup to moderate temps, it basically gets worse with each degree in temp.
I'll post my results as the saga unfolds but again the question remains - were the clutch disc's weak and redesigned and/or is it normal for shuttle shift with loader to rip them out over time? Anyone with similar results please chime in - to date I have talked with at least 10 kubota tech fellows and they have no idea's except "split'r down"...
UPDATE 6/25/12
Tore it down, splined wasted on clutch disc, the remaining components looked brand spankin new - replaced complete with "puck" style disc, seals, etc - I've attached image dunnow if you can see it, BUT for the record the clutch worked GREAT cold but hung as it heated up. Bottom line, clutch had 300 hours on it and it ate the spline, the fellow who had it before has put three clutches in it, I am the new operator so we shall see..
UPDATE: 6/5/12
UPDATE 6/5/12
UPDATE 6/25/12
