It seems like they should work OK. You would have to use the CAT3 version of the quick hitch to match your tractor and add bushings to the CAT2 equipment.
Mine are CAT1 and CAT2 so they are slightly different. I found some large flat washers that fit over the CAT1 hitch pins and used lynch pins to hold the bushings and washers in place.
