F FARMHOUSE New member Equipment KUBOTA B3000 Mar 19, 2022 2 0 1 DRACUT MASS Mar 19, 2022 #1 how to replace a left rear axle seal on a kubota B3000 is there a snap ring holding axle or do you have to remove side case ?
whitetiger Moderator Staff member Equipment Kubota tech..BX2370, RCK60, B7100HST, RTV900 w plow, Ford 1100 FWA Nov 20, 2011 3,794 2,195 113 Kansas City, KS Mar 19, 2022 #2 FARMHOUSE said: how to replace a left rear axle seal on a kubota B3000 is there a snap ring holding axle or do you have to remove side case ? Click to expand... Attached is a parts breakdown of the rear axle. You will have to remove the axle housing and disassemble it to replace the seal. Attachments B3000_Rear-Axle.pdf 116.9 KB Views: 282
F FARMHOUSE New member Equipment KUBOTA B3000 Mar 19, 2022 2 0 1 DRACUT MASS Mar 19, 2022 #3 whitetiger said: Attached is a parts breakdown of the rear axle. You will have to remove the axle housing and disassemble it to replace the seal. Click to expand... Thank you 3 hrs got it done hardest thing was putting the filled tire back on.
