Remote Hydraulics B7800
dmoore
2006 B7800, RC72-BA 72" mid mount mower, RB 1672 72" rear blade
Feb 8, 2010
84
9
Exmore,Virginia
I would like to be able to articulate my RB1672 rear blade on my 2006 B7800. Has anyone done this? Can it be done? Thank!
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
Yes, pivoting side to side without getting off of tractor.
5,242
It can be done. The question is how much effort. Does the blade have provision for cylinders? Then after adding the cylinders you need to add a valve. Thats the easy part.
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
Yes, GP Outdoors posted an install video of it. Granted, his tractor is not a B7800 but same blade.
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
No, I only mow my 5 acres with a 72" belly deck RC72-27BA
5,242
Then you would need to get the hydraulic outlet block (020, 040, 050) and return fitting (010) to tap into the hydraulic lines for your remote valve. Looks like Messicks wants about $38 for them.
3,215
It certainly can be done.
You need to tap into the hydraulic system using something like Dan posted. In my case with a B2910, which is very much the same tractor, the adapter block was a little different.
BUT then you also have to buy the correct control valve(s) and hoses, and the hydraulic cylinder. If you are going to do it, much better to install more than one control valve and be done with it. You will likely find in the future you would love to have at least two control valves.
When I added control valves/rear remotes I installed four, just in case, but think three would be the max needed ever.
So yes you can do it yourself. But it takes a little effort to accomplish. AND more than just a couple bucks for the parts.
BUT worth it, in my case anyway.
5,242
Rough estimate:
LP 301-425A angling kit $350.
Two spool valve with hoses and quick connects - $300.
B7800 hydraulic outlet block and tank return - $40
dmoore
Feb 8, 2010
84
9
Exmore,Virginia
That's what I'm thinking! Thanks for chiming in Henro!
