Front mount blower for b7300?
Bpwight92
1998 kubota b7300
Ny
Are there any options for front mount blowers nowadays for a b7300? Not much info out there. I believe the one I need is a b2650 can anyone confirm that? I have a smyth rear mount now and it barely moves snow.
7,310
Kubota shows B2650 and B2651 for the B7300 HST. I did not try to figure out the differences.
5,255
1,058
There is a product made by Erskine.
It is a front blower driven by the rear pto.
Erskine
Smyth Welding in Canada has a line of front blower products like Erskine but different in that the rear drive is done using two gear boxes instead of a short pto shaft.
They have dealers in USA. I think their 48" front mount is recommended for 20 HP.
Thesse front blowers are much heavier design than the Kubota worm gearbox style
Bpwight92
1998 kubota b7300
Ny
Wow thanks for the info, I sent smyth an email requesting a quote we will see what they come up with
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
kubotasam
Apr 26, 2010
1,212
137
Alfred Maine
Looks like a B2733 or B2733a subframe will fit. Much newer design than the B2650 with B2651 subframe.
If you got a B2733 subframe then you could add a BX2750 snow blower. Much easier to find than the B2650. You would also need to obtain the correct pto driveshaft. subframe from tbn 5.jpg
BoltBuster
B2920, LA364, BH65
Apr 14, 2018
10
Hudson, NH
I have a line on a BX2763A snow plow with a B2733A quick hitch for my B2920 tractor. My tractor has an LA364 loader and a subframe for my BH65 backhoe. I need to know if:
1) I can attach B2733 in the presence of the loader subframe and the backhoe subframe, and
2) Will the B2733 interfere with the loader such that I can't attach the loader while the B2733 is mounted?
I have been searching for the installation manual for either the B2733 or B2733A with no luck so far.
K.P.
B7300, LA272 FEL, B2650, 8160 Ballast, G2460G Mower, Danuser 20/40, Woods RB60
Aug 11, 2010
84
Cary, IL
The BX2750 is the replacement for the B2650. You still need the original mount. I don't believe the BX mount or sleeve hitch will work on a 7300.
