hydraulic pressure -loader and 3 point
David-in-OK
L355SS, brush hog, box blade
Aug 2, 2020
58
Oklahoma
My loader and 3 point dont have the "oomph" I think it should (L355SS). How can I check its hydraulic pressure?
old and tired
L2800 HST; 2005; R4
5,306
On what are you basing that assessment? Hydraulic pressure gauges are inexpensive and easy to install in the pump circuit. You can install a JIC tee on the inlet to your loader valve and use it as a test point. Keep it capped when the gauge is not connected. To get a pump presure reading just roll the bucket back hand hold it there with the control lever. That will block the pump flow and deadhead it against the system relief.
5,257
1,043
When was the last time you checked and cleaned your hydraulic filter screen?
Recently a number of problems posted on the forum have been traced back to dirty screens.
