H....!i everybody
gabor
Kubota gl 25 grandel
Jul 1, 2021
Oregon
Hi ! anybody familiar with Kubota gl series tractors ? I have a gl25 and have problem with the propeller shaft for the 4 wheel drive .I need help ! please!
3,528
Not familiar with a GL25…. but curious about your ”problem”…..
Is it turning when it shouldn’t?
Is it not when it should?
Is it missing?
Is it green/yellow?
gabor
Jul 1, 2021
Oregon
Is it missing?
Is it green/yellow?
Hi. thank you for the reply. it s not turning when it should . it is a Kubota gl 25 Japanese
it is like most L series's I would think. I took out the mid section shaft under the crank case with the two couplings ..they are fine . the shaft coming out from the transmission feels loose inside ..like I can wiggele it up and down and sideways . with out a 4x4 printout not shure if the shaft is broken or just slide out from a inside coupling . the 4x4 lever rod goes to the very back of the transmission housing .
what do you think ?
