Little Dump Trailer
BXHoosier
BX24
Jan 21, 2018
512
630
Indiana
I built this 1 ton yard trailer about 10 yrs ago. It’s built mostly from 3” channel iron. The bed is 36”x49”. It has a 2”x8” dump cylinder and 1200 lb ea trailer hubs. The sides can be quickly removed if I need a flat bed or mobile work surface.
2EFEEE6E-CF09-4232-967D-09EDD5EC268C.jpeg E9777B74-53A1-4731-99C9-813F656A332C.jpeg
3,570
I put the plywood UNDER the box to support the bottom.
Good idea. Think I might have a piece of OSB laying around to throw in there.
3,570
3,570
You have room in your garage???? Wow, you're weird! o_O
Not much. It is a 25' x 25' with a 16' door. Currently there is a 10' x 6' 7000lb dump trailer, a Yamaha Rhino SxS, a 4 wheel Rhodes Car bicycle (large), a large log splitter, a second B670 backhoe, a radial arm saw, 3 rollaways, a vertical bandsaw, 2 full sets of Rhino tires & wheels, a compressor, a large shop vac, a floor model drill press, two work benches, a 4 wheel garden wagon, 4 ladders, a bunch of misc stuff, and the two small dump trailers.
Needless to say, to do anything in there requires me to move some stuff out first.
5,596
I got tired of having to put ain in mine so HF had solid tires, and thats what on it,, works well for what I use it for,, oh yeah the HF wheels were cheaper them tubes.... Wait did he say room inthe garage??? Nawww that cant be
3,570
I'll try to shoot a pic next time I'm there.
