L1501 Never had any leaks prior. Hooked up 4' bushhog ran for 3hours in 90+ weather. After about an hour noticed small amount of fluid coming from gear shift boot. At end of work had a good bit more.
When lifting implement all the way up, the pump was straining but otherwise no problems when running. Checked fluid level with dipstick via the fluid add port. Have about 4 1/2 inches on dip stick. No noticeable water etc. Comments and suggestions are most welcome.
