rbargeron
Good advice! In four wheel drive, the front tires are "geared" to cover slightly more ground than the rears, so as to provide steerage on soft ground. . The front are "pulling" the rears just slightly. That is OK in mud or other slippery stuff. On pavement, with use, you get the result you show in your picture. One note. The preceding only applies if the tires (front and rear) are sized within manufacturer's spec. Kubota does not publish it, but if you request, you can get your tractor's "gear ratio". With that in mind, you can determine what tire sets (front & rear) will work properly with the ratio.Noticed this on a tractor with 900 hrs. If yours runs on pavement a lot, take it out of 4wd ! View attachment 60881
The information needed can be found in the Illustrated Parts Lists. The tooth count is given for each gear in the system. Following it through from rear pinion to both axles the number of front turns for each rear turn can be figured. Its called "Transference Ratio". For my L5450 it's 1.51 : 1 and for my L48 it's 1.54 : 1....Kubota does not publish it, but if you request, you can get your tractor's "gear ratio".
Hello rbargeron,The information needed can be found in the Illustrated Parts Lists. The tooth count is given for each gear in the system. Following it through from rear pinion to both axles the number of front turns for each rear turn can be figured. Its called "Transference Ratio". For my L5450 it's 1.51 : 1 and for my L48 it's 1.54 : 1
To find the actual degree of "scuffing" going on, multiply this number by the circumference of your front and back tires. You'll get two distances (front distance traveled is slightly larger). That's the "Inter-axle Ratio". For the L5450's its 1.04 : 1 and for the L48 its 1.03 : 1
More related discussion here.
Thanks GeohornLook thru your Owners Manual and the compatible tire-sizes are listed for your model.
Example:
Hey rbargeron,The information needed can be found in the Illustrated Parts Lists. The tooth count is given for each gear in the system. Following it through from rear pinion to both axles the number of front turns for each rear turn can be figured. Its called "Transference Ratio". For my L5450 it's 1.51 : 1 and for my L48 it's 1.54 : 1
Hmmm If were a road vehicle... like a car....Noticed this on a tractor with 900 hrs. If yours runs on pavement a lot, take it out of 4wd ! View attachment 60881
Just for informational purposes, here is what I received from Kubota customer service when I asked about the front to rear axle RPM ratio. I believe that the ratio they refer to as "Gear Ratio" is the front to back axle RRM ratio. Would you agree?Different situation - a large amount of tread depth has been abraded away in the post #1 pic.
40 mph for a tractor is supersonic.... a more likely average speed would be 1-3 mph.... so 1800 miles, using your calculus (not considering the larger O.D. of a tractor tire...which would further reduce the number of revolutions/tire-wear-factor....all of which presumes the tires were installed the same time and are same age as the rears.)Hmmm If were a road vehicle... like a car....
900 X 40 (miles per hour average "guesstimate") = 36,000 miles.
Not too shabby for a passenger car tire much less a tractor.
The tractor will certainly see less "mileage", but the conditions of use are rough. Fronts always wear the fastest anyway.
19thSF - The "gear ratio" given on the list doesn't appear to be supported in the WSM. The 2013 version of the WSM for B2050 B2350 B2650 B3150 covers all the options - including Bi-Speed Turn, where the amount of front "pull" jumps up on sharp turns . Was that list tied to your serial number?
I di not mention a serial number. I have attached my inquiry. When I asked them what they considered as the correct lead, they answered with "acceptable tires"19thSF - The "gear ratio" given on the list doesn't appear to be supported in the WSM. The 2013 version of the WSM for B2050 B2350 B2650 B3150 covers all the options - including Bi-Speed Turn, where the amount of front "pull" jumps up on sharp turns . Was that list tied to your serial number?
