Anyone needing part number or details, i have soom here.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
11
Leafy England....
Hi guys, time to try and repay you all for the help i've received from you all to date.
On the basis of how hard and time consuming it can be to source original spec and parts number of older kubota kit, i thought i'd offer my help with a few bits.
I have an original spec sheet for the S-850 rotary tiller
Also have an original B6000 parts manual (100 pages worth) which has all the original parts numbers etc and also has the all the part number etc for both versions of the s-850 tiller.
there is an original operators manual inc all part number and fitting instructions and specs etc for the 619B backhoe.
also the same manual as above with all teh same details etc but for the KUB206 front loader
a full service manual for the B6000
finally the assembly,operation ,maintaince and spare parts list for the Backhoe models, 130 and 180.
KB180 backhoe spares manual etc. Contains spare parts numbers of all parts, schematics etc even modified part numbers and diagrams of the modified part for specific serial numbers of backhoes, a really handy to have book.
afew other spec sheets on b6000 kit also.
all the above have very good diagrams etc which i found a real help let alone finding that elusive part number.
most of above is for the B6000 but can also be found fitted on other kubota tractors aswell, the backhoes and loader are an example.
if you need any part numbers or parts drawing / schematics or other info for the above , drop me a line and i help you out by email or fax.
thanks
rob
Rob
Nov 22, 2009
679
11
Leafy England....
Its my pleasure vic:D:)
I've just added another one KB180 backhoe spare manual etc. Contains spare parts numbers of all parts, schematics etc even modified part numbers for specific serial numbers of backhoes, really handy to have book.
farmintom
kubota b6000
Aug 19, 2011
Newton Falls Ohio
Rob,
Do you know how the kubota b6000 with a k 44 mower deck belt runs from the tractor to the deck? The way i have it the blades turn the wrong way.
Thanks,
Tom
SturmUndDrang
B6000 w/ FEL, BH, PHD, RT
Apr 26, 2020
Federal Way
Rob,
Hello from the West Coast of the USA. Thanks for paying it forward with your offer to share materials.
Regarding the 619B backhoe, would you happen to know where is the serial number located on each unit? My parts dealer is asking for the info in order to give me the correct boom cylinder seal kit.
Thanks for any details you can share.
thanks
rob
thanks
rob
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Rob,
See below attachment for 619B backhoe serial number location:
SturmUndDrang
Apr 26, 2020
Federal Way
Wow... fastest help ever! Thank you, Wgator! They really make you work for the number with respect to the placement. Would never even have thought to look there...
Have a great week. I will be rebuilding the boom cylinder as soon as I get the correct seal kit!
SturmUndDrang
Apr 26, 2020
Federal Way
So the serial number is on the edge of the main frame housing. The number appears to be hand stamped and eroded by rust. A 674. You have to work to see the 6.... Thanks again, wgator!
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Just as a FYI... 2 of my loader cylinders were obviously replaced, if I ordered parts they would be wrong. When I need seals I take out the gland & piston and carry them into my local hydraulic shop. They roll the internal seal into the gland while I'm waiting and only bill for the parts.... which are substantially less than re-packaged Kubota seals.
3,672
That looks more like a casting number than a serial number to me.
