L3301 and rear chains - what do I need?
pghponton
L3301 w/LA765 FEL
Jun 29, 2016
Salem Twp, PA
I have an L3301 with R4 15x19.5 tires. I need to put chains on them. I have read contradicting information regarding whether or not I need spacers. Can somebody help clarify for me please exactly what I need? Thanks in advance.
baronetm
L3901HST w/FEL, 3rd fnct. BH77 BH, 5' Bushhog, 6' BBL, 42" Forks, WoodMaxx WM-8H
Apr 19, 2017
122
12
South Central VT.
I have a L3901 with the same size tires, my dealer told me when I purchased it that I would need spacers if I ever wanted to run chains, so I purchased them as part of the sale. He stated there is not enough clearance for the chains without them.
ayak
L3301 HST
Feb 16, 2018
693
966
WV
I ordered in 3” Bro-tek Spacers to enable this on my 3301 with R4s (and just widen Butch up a little). Great customer service from Richard at Bro-tek. Now I’m looking around for the easiest way to pull my loaded rear tires off without breaking my back. Actually ‘pulling’ them off won’t be hard—it will be putting them back on. I won’t be widening the front.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
I was told I had to have them on my b 2710 with turf tires. Well I run around 18 to 20 hrs a week no spacers but they are low profile chains and are tight tight. Probly should have spacers but then I need a wider bucket. Mabey in the next year we will see where financially can do but for now it works I just keep them tight.
pghponton
L3301 w/LA765 FEL
Jun 29, 2016
Salem Twp, PA
ayak - Are 3" required or can I go smaller? Have you hung the chains on the tires to see how much clearance you have with the 3" spacers installed?
Ikc1990
Dec 2, 2020
292
130
Vermont
Best thing todo is grab a tape measure and measure from tire to closest point of fender or bolts or catch items. Most chains recommend 3 inch or more clearance my low pros are at least 2.5 inch clearance. Then go from there. On spacers keep in mind width of bucket or snowblower you dont want tires wider than your implements. That's part of my problem if I put spacers needed like 2 inch I need to get different bucket, which is all on agenda for near future but that's another ordeal lol
ayak
L3301 HST
Feb 16, 2018
693
966
WV
Likely depends as well on other factors such as chain type and fit. I picked 3” spacers because those gave me the equivalent width on that rear as R1’s have that themselves are moved all the way out. I’m on hills a lot so that was really my primary reason. I haven’t even procured any chains as of yet.
ayak
L3301 HST
Feb 16, 2018
693
966
WV
Picked up one of these to help get the rear R4’s off and on (once the weather warms up, anyway).
ayak
L3301 HST
Feb 16, 2018
693
966
WV
That looks like a great accessory, can you share a link for where you got it, thanks.
Picked it up off Amazon:
Figured I’d save my back and use it for my truck tires, no matter what. Has a 550# weight limit (unfilled R4 rears on the l3301 weigh 200#). The rollers are 11” long and will work pretty good for lining up the studs when the wheel goes back on.
3,203
I envy you guys! If only that would work on my dirt floors...OK, I suppose it might if I layed down a piece of plywood first...BUT OUCH...low grade plywood sheeting is now over $40 per sheet here!
ayak
L3301 HST
Feb 16, 2018
693
966
WV
As much as I liked using that tire dolly I picked up off Amazon, the backhoe itself really made the job easy.
