Welcome to the forums. This is the best site for information on Kubota tractors bar none. You question about larger front tires for your tractor is complicated, to say the least. Because your tractor is a 4 wheel drive model you cannot change tire sizes in the front without changing the rear tire size too.Anyone put a taller front tire on there bx series, seems 12x8x10 turf is not large enough?
I posted a couple of times about going to a larger tire size for the BX18xx series tractors. I went from the stock tires for my BX1860 to the stock tires for the BX2360. The OPs BX2380 has the same stock tire size that all the BX23xx series has. I am not aware of a larger tire size available for the BX23xx series or the BX25. That's not saying there isn't a larger tire size available, I am simply not aware of one for his tractor. The reason I have a little familiarity with this subject is because my neighbor has a BX2350 and he was looking for a larger tire size and was unable to find one.I remember someone posting here that one of the BXs use larger tires than others. I do not remember the details. But want to think the person posting went to the larger tires to get more ground clearance, and was happy with the result.
Maybe someone can add the details, or point out that I am nuts for remembering this...![]()
