So I searched for an answer to my problem but I couldn't find it. The tractor in question is a B7300 HST around 750 Hours. I hope someone knowledgeable can help me with this. I recently changed all of the fluids, filters, and cleaned the screen on the banjo bolt and the 3 point hitch functioned properly for ~1 use. After letting the tractor sit for a few weeks I started it up this weekend and the 3 point hitch would not lift (always drop it down and then put it in the "Neutral" Position).
After doing some troubleshooting the hydraulic pump isn't getting fluid from the reservoir at the back of the tractor. Attached is a diagram to show the parts I am talking about. I pulled the rubber hose (#70) off of the supply pipe (#40) and fluid barely trickled out. I've tried cracking the high pressure side (#160) to see if any air pocket can pass and no luck. I read somewhere that you might have to overfill the reservoir in order to "Prime" the pump, but no luck. I couldn't find any sort of air bleed on the pump.
I finally decided to crack the banjo bolt and once freed from the housing fluid flowed very well not out of the end of the pipe but where the banjo bolt goes. It almost seemed like the screen on the banjo bolt is too fine to let the fluid run through it quickly. I double checked and the screen was clean.
I used Traveller Universal Tractor Trans/Hydraulic Fluid from tractor supply.
My questions:
Should fluid freely flow out of the end of P/N 40 if I removed it from the rubber hose (#70)? or would the pump cause a vacuum and suck the fluid towards it?
Should the pump self prime?
Is there a way to Prime the line?
I don't think the pump is bad and I only ran the pump for short intervals to not damage it. It almost seemed like I lost prime when the tractor sat or when I previously changed the fluids.
Appreciate the help in advance.
My questions:
