Mower deck gear box gears
GEP
109
Benton Harbor, Mi
I am in need of a set of beveled mower deck gear box gears Part number: 76539-99020 The gears are labeled no longer available. I just cant find out if any gears from other model deck interchange. I called several dealers with no luck. The deck model is RC60-G20
Thanks
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
If you know the manufacturer you could contact them. You may end up with a new gear box if it's too old.
5,257
1,047
Thanks
When I look on the Messicks site I see the updated gears available ( with the part number you have) as noted below with 5 to 7 business day delivery.
Messicks parts,
Kit, Bevel Gear 76539-99020 $429.18 5-7 business days
Suggest you call them.
I looked on the Kubota.ca web site and see these gears available when I use the model RC60-21B that Messicks says the above part number fits along with your model.
It can all be very confusing and if you have a less than enthusiastic parts guy the easiest thing for him/her to say is NLA (No Longer Available)
Workerbee
Zd21
Mar 1, 2020
318
179
MN
RW, thats an OEM Kubota deck, going by the number provided. There are a lot of RC decks but most have another letter like K behind the RC. Perhaps a visual comparison would be the best way if dealers cant help. Id bet that a used gearbox would be much cheaper. I know that new gearboxes run 600-1000 and gears, bearings, and seals would likely be more.
GEP
109
Benton Harbor, Mi
Messicks parts,
Thanks Dave
I tried Messicks it was just before 5 pm no answer on the phone. Monday I will call at 8am they are in my time zone
