Filrer change on my m135gx
Hayroller
Kubota m135gx JD 569 RD Baler..Krone 320 easy cut disc mower..Kuhn speed rake.
Jun 7, 2020
10
Oklahoma
I have slow and sluggish responses from the hyds...gate is opening and shutting too slow on my baler..i imagine its the filter and possibly a suction screen if this tractor has one.
Another ? is am I going to dump all the fluid when I remove the filter..thanks for any info.
SidecarFlip
Banned
557
Depends on how fast you are with a filter change....:rolleyes: Have everything ready to go and whip the old ones off one at a time and whip on the new ones. Are you sure there isn't a restrictor in the lift gate cylinders? My NH round baler has them to keep the tailgate from closing too fast. Far as I know, unlike the smaller Kubota's there is no strainer, just the high pressure filter and the low pressure filter which interchange (at least on my M's they do).
I have to say I dropped my fluid at 50 hours and changed it out.
You'll loose some so have a drain pan underneath unless you are on gravel. If on gravel, it keeps the dust down.
The first filter change is always a bugger. Kubota OEM from the factory filters are always tight. Be prepared to 'wrench' on the filters. If I remember correctly, I rammed a big screwdriver through mine and levered them off that way but then again, I dropped my fluid anyway.
I suggest using Kubota Filters over anything aftermarket. They really don't cost a lot more and you know they are made to OEM specs.
Hayroller
Jun 7, 2020
10
Oklahoma
