BX2380 setting a returnable 3-point hitch height
DickHob
BX2380
Mar 26, 2020
Sterling, NY
I am a new owner of a BX2380 with a 3-pt quick attach. I have a box blade, rake, and scraper (no wheels on any of them). When I find a working height setting for the blade/rake edge, I would like to be able return to that height.
There is no stop adjustment allowing me to return to my original setting. My dealer says most people use a bolt on chain to control height. I can do this but I'm wondering what others have done to solve this problem.
Any suggestions would be appreciated.
Thanks
DickHob
i7win7
Feb 21, 2020
3,252
3,781
Central, IL
Your BX has what they call a 1/4 inching control lever returns to center when released. What you want is a positional control - lever stays where you put it.
The B and larger tractors have it. Dealer willing to trade up? 3pt attachments will work the B model or a green tractor.
powersrp
B3350
Apr 2, 2017
95
Indian River MI
can you put an adjustable stop on the 3 pt control lever? The B’s have them, unsure about other models, or how your console/lever is configured. a pict of the console/lever might get you more ideas.
bcp
BX2360
Apr 20, 2011
645
77
SW WA
On a BX, the farther you move the lever, the faster the implement moves. The implement stops only at bottom or top of travel, or when the handle is released and spring-returns to center. A travel-stop would only limit how fast the implement moves, not how far. It was odd to learn after having an 8N.
Bruce
4,102
Was in the back room of garage today and found the 3PH kit that came with my BX23S... I still haven't used...sigh it's been 2 YEARS already !
powersrp
B3350
Apr 2, 2017
95
Indian River MI
Ahh, gotcha now, a chain would be inconvenient, but maybe with a turnbuckle it would work, its not a whole lot different than any other 3 pt implement setup, ya have to use the quick buckle to level or angle the attatchment.
DickHob
BX2380
Mar 26, 2020
Sterling, NY
Re: BX2380 setting a returnable 3-point hitch height- UPDATE
Here is some proof of concept info.
1. Notched each end of a 2in pipe halfway so I had a solid surface to contact the ROP. I drilled 5/16in holes at the notched ends
2. Drilled and tapped the ROP to accept 5/16 machine bolts.
3. Drilled a centered hole in pipe for a 5/16in bolt hook to hold the upper chain link in the adjustment chain.
4. To connect the bottom of the chain to the implement pin I used a climbing rope clip hook. I used a small piece of wire to keep the chain link away from the pin.
This setup appears to work well. I can control the adjustment of my rake in approximately ½” increments. If the 5/16” hardware fails. I’ll go to 3/8”. Real test is going to be my box blade this weekend.
I also have a turnbuckle if I need a finer adjustment (thank you powersrp)
