BX2380 forks
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
Really depends what you're looking to do.
If you have SSQA, find some SSQA forks as light as possible, to maintain max lifting capacity.
I use a set of Titan FEL (non-SSQA) clamp-on forks, that work very well for what I do, which is very light utility stuff. These would not be good for max weight capacity, as they move the load way out front. But again, for light stuff, they are cheap, light, quick to install, and work great.
4,064
I've got a set from HLA, rated for 900#, from Kubota dealer that I bought the tractor from.
They are tricky to get used to, joystick needs 'slow,old man mode' option
Cfrazer
BX2670-1,FEL, BX5450, BBox, GS1548, RB1560, QH05, AI2 Forks, SS Curtis Cab
Jan 22, 2018
86
North Rose, NY, USA
Has anyone tried the BX/A12 units weight of units look good.
I don't have SSQA, so went with Ai2's forks and quick attach system. they work great. I've only had them about a year but already my favorite attachment and the carriage and forks only weigh 160 lbs combined so I don't lose much lift capacity.
The SSQA version carriage weighs about 20 lbs more so total 180 lbs. Just give Tony a call and he'll give you any info you need on them, easy guy to talk to.
shiraz627
BX23S Piranha toothbar, Underarmor, PFL1242 pallet forks, BXpanded thumb, ripper
Aug 1, 2018
206
Kingsland. GA
The price was well over $1000 with shipping. I got the Kubota PFL1242 for $570 in my truck. To expensive for the small weight savings. Then they do not deliver them to your house!
